It is currently Tue Aug 12, 2025 4:28 am
 Post subject: Bridge plate question
PostPosted: Sun Jan 17, 2010 10:06 pm
First name: Gregg
Last Name: Cuoco
City: Albuquerque
State: NM
Zip/Postal Code: 87114
Hi Guys,
I recently purchased a set of 12 string Dred plans from LMI, there drawn by Scott Antes.
I noticed the bridge plate is huge, its approx 2.5 times the area of the bridge. It extendes forward of the bridge 1/2" and aft of the bridge 1.25". It's basically a huge tirangle. Seam like a lot of mass glues to the underside of the top.
Is this how you guys build your 12 string bridge plates ??
Any thought would be appreciated.
Gregg
Gregg
PostPosted: Mon Jan 18, 2010 6:27 am
Well, I can't answer your question directly, but I've picked up from around here that Antes plans are notorious for being overbuilt. I have that plan also, so I'm curious to hear what others have to say about it.
PostPosted: Mon Jan 18, 2010 7:53 am
Yes, my bridge plates on 12's are quite large, but then I also use a different style of bracing on them. Here's a comparison of my 6 and 12 bridge plates.
My tops are also quite thick, but I use .070"-.014" strings on 12's.
I've not seen the Antes print, but you just can't make a blanket statement like they are overbuilt. A 12 string is a completely different animal from a 6. Depends on the strings you want to use, the tone you are looking for, and how you are going to tune them. If you want a "harpy" sounding 12, lightly built and extra lites might work, but if you are looking for a fat tone, heavy strings and an "overbuilt" box with a long scale tuned down to C+ or B is the way to go. Remember you have twice as many strings that drive the top, so there is a lot of power there.
PostPosted: Mon Jan 18, 2010 11:01 am
If you don't compensate the plate for the additional torque you top will not take the stress. Yes the plate must be that large.
PostPosted: Mon Jan 18, 2010 11:11 am
Really nice looking work, Hanns! [:Y:]
PostPosted: Mon Jan 18, 2010 11:39 am
First name: Gregg
Last Name: Cuoco
City: Albuquerque
State: NM
Thanks Guys !!
Gregg
